Greetings,
I am conceptually designing a simple mechanism on the fly. Hence, I sometimes want to add or delete a face, etc., after I have created a body and have moved it around. This trips me up when I choose to make said changes by modifying my sketch (as it hasn't moved with its body). My question is: How do you move a sketch when you move its body?
Solved by innovatenate. Go to Solution.
Are you utilizing the Timeline in this design? You may be able to roll the timeline back to before the move command and then edit the sketch....
I hope this suggestion helps, please let me know if it doesn't or if you have any other questions.
Yes, I am utilizing the Timeline in this design. I like your idea and tried it. Unfortunately, it doesn't solve a situation like mine. I want to modify the sketch where the part is currently located so I can key off of geometry on surrounding bodies (as in "project" geometry into my sketch, etc.).
Thanks for your suggestion! If you, or anyone, knows of a tutorial or Youtube clip where someone shows how to change designs after bodies are thrown together in a conceptual assembly, I would appreciate a link.
Is the sketch located in the Sketch folder inside of a component? Did you convert to a component before moving?
You may be able go back in the timeline back and then move the sketch prior to making a body or component. If the sketch is part of a component. Then the sketch will exist in the component's coordinate system. This may enable the body and sketch to move together.
It's really hard to say what may work 100% without seeing the file. Is there any chance you could share the design with us?
See this Tip for how to create a public link to share a file.
Bodies only, no components. Piqued by your second question, I created a body with a sketch, created component and moved the component. The sketch did not move with the component.
Thanks.
I made a quick Screencast to show something that may help. You can use components, which have thier own coordinate system to keep bodies and sketch together.
I hope this helps. Let me know if you have any questions.
