Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How does the "Setup Sheet" work?
17 REPLIES 17
Message 1 of 18
leesty
4314 Views, 17 Replies
Hey guys. Trying to figure out how to use the setup sheet after I am done with post processing. I click and nothing happens. Same in the drop downs.
I would like to be able to use that feature.
Many of my parts require different setups as I'm sure you guys know. It would be nice to be able to give the operator some information about how to setup the part.
I did some searching and just didn't find any mention of it.
Thanks.
Lee
17 REPLIES 17
Message 2 of 18
curtis.chan
in reply to: leesty
Hello Lee,
Great to hear you're using CAM for Fusion 360!  In regards to the Setup Sheet, try 'right clicking' on the setup in the browser and save it to your desktop.  Will that workflow work?
Message 3 of 18
leesty
in reply to: curtis.chan
Thanks for that.
I actually just returned to say that I did find the information about the setup sheet.
It was in the least likely place. In the help files of the software. 😉
I was neglecting to select the machining processes.
All better now. Nice feature BTW.
Thanks.
Lee
Message 4 of 18
curtis.chan
in reply to: leesty
Great to hear Lee!  Don't ever hesitate to reach out with any additional questions.
Best,
-Curtis
Message 5 of 18
herzinj
in reply to: leesty
On a side note, and completely unrelated, your avatar is awesome!  If there was an award for that, I would certainly give it to you.
Keep up the good work with CAM, and as Curt said, please feel free to reach out with whatever questions you have.
James
https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png
Message 6 of 18
jeff.walters
in reply to: herzinj
The setup sheets are .CPS files and can also be run thru the post dialog. Just scroll down and you will see Setup-sheet.cps (this is the default HTML format), and 2 setup-sheet-excell.cps(setup-sheet-excell-2007.cps) these two will output in yep excel  format.
Jeff Walters
Senior Support Engineer, CAM
Message 7 of 18
leesty
in reply to: jeff.walters
Thanks a bunch, Guys.
Message 8 of 18
Sandflo
in reply to: leesty
Hi. Are the setup sheets editable? Is it possible to get you company logo in there somehow?
__________________
Gigabyte P35 V3 , Windows 8.1, Sweden
Message 9 of 18
leesty
in reply to: Sandflo
Sure.
You can edit them. They are in HTML. Just add your logo to the completed file and save.
Message 10 of 18
leesty
in reply to: leesty
Just remember to place the logo file in the same folder that you saved the setup sheet in.
Message 11 of 18
Sandflo
in reply to: leesty
Hi Again!
How exacly do i put mu logo in the setupsheet, where do I edit?
__________________
Message 12 of 18
leesty
Well, you really need to know how to edit a web page.
I have Dreamweaver for that, so it is a simple matter. It can be done in text format though. Just a little harder to input the code.
This is the code I used to input my logo.
<img src="sharkguard.png" alt="Shark Logo" name="Shark Guard Logo" width="160" height="50" hspace="215" border="0" align="top" />
It's really not too hard.
Message 13 of 18
590213
Hi Jeff
I dont understand where and how I actualy change the default from HTML to Excell
Regards
Andy Robinson
Message 14 of 18
daniel_lyall
in reply to: 590213
it would be good if we can get some info on how to do this a step by step guide.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 15 of 18
curtis.chan
Hi Johan,
I'll monkey around with this and will create a video for you all.
Best,
-C
Message 16 of 18
daniel_lyall
thanks @curtis.chan when you go to John's school take heaps of picks
Daniel Lyall
The Big Boss
Mach3 User
Message 17 of 18
design1VP8DL
Hi Curtis,
Did you ever create this video?
David
Message 18 of 18
curtis.chan
in reply to: design1VP8DL
Hi David,
Matt Nichols from the CAM Team did a Webinar on Setup Sheets.  Here you go.
https://www.youtube.com/watch?v=WaqP3qt-Nyo
-Curt Chan
