I have been using Fusion 360 for the last 3 months and I really like the tools avaliable but the performance is awfal, it crashes very often, a bit laggy and for the last 3 or 4 days I have not been able to open a document, each time I double click on a file to be opened it goes on a loading loop and never opens the file, the only way I have found of working with one (if Fusion 360 opens atall) is to right click on a file and insert it. I have a Mid 2012 Macbook Pro 13" with an i7, 16GB of RAM and a 256GB SSD with OS X Yosemite. I have uninstalled and re-installed it and nothing changed, all this started happening when I updated it last week. Does this happen to any of you and if so would you know who to fix it? I find very shaemfull to make such an expensive piece of software that doesn't even work properly, it feels like I am using an alpha version of the program, not happy at all.
Posted in wrong product forum - should be in the Fusion 360 forum.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I could not find the tab you mentioned on the help menu. This are all the options I get
I am sending a report for most of the crashes I am geting, my registered email is: elrumo97@me.com
Thanks for your answer
Hi elrumo,
In Fusion in the upper-right corner you will see a "?" drop down menu. Click on that menu and you will see an option called, "Diagnostic Log File".
Click this entry and Fusion will gather your log files and create a ZIP file which you can then send in.
In the meantime until we review the log files you can also see if it may be related to a bad browser cache file. For this you can delete the existing cache and have Fusion rebuild it. To delete the browser cache:
If you have any further questions don't hesitate to ask. We look forward to helping!
Regards, KpB
Hi Elmuro,
once you will use this command, you should see window like this:
DiagnostiLogFiles will be stored in folder like this (if you have .com installation):
/Users/<current user>/Library/Application Support/Autodesk/Autodesk Fusion 360/FusionDiagnosticsData
If you have Fusion installed from App store, you could find this folder here:
/Users/<current user>/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk/Autodesk Fusion 360/FusionDiagnosticsData
Regards
Roman
Fusion QA team
Thanks for sending in the log files to my email. I am currently takeing a look. I will update this post as I know more.
Autodesk Fusion
Join Fusion Insider
