Hi
you check with a new file the export, our check if the geometry you're saving is watertight. and try to save as to the HUB then download.
Best Rishi
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
thanks for your help but export from a new file is also not working.
I found no geometry errors in my current file.
Exporting via the HUB is also not working, same as in the app nothing happens when your press the save or download button.
Maikel
Hi Maikel
can you post here, our send me rishivadher@hotmail.com a sample file to test it.
best regards Rishi Vadher
Rishi Vadher
Personal Page
Are you exporting from your Dashboard or are you exporting from the the local application? ....tools menu or in-app file menu?
See the below tip for further insight.
im having the same problem. ive saved my file and then try to export it via: data -> export, but its also nothing happening. i have already exported files but since two days im not able to export anymore. ive tryed exporting other models the same way, but it also doesnt work.
please start a new thread.
you should be able to access connected drives via the path.
günther
@e-scholtz wrote:
ok, it looks like i finally found the issue. the saving folder is on an external drive. i havent logged on the drive and it looks like the export window just doesnt open, if the device is not connected. so no chance to choose another device or saving folder... good to know.
Sounds like the very old bug reported in this thread with a workaround.
Mark
Mark Hughes
Owner, Hughes Tooling
