OSX 10.9.5
I was getting the messgae to updat or quit so I uopdated and when the update got done loading it said Fsuin will restart, however it never did restart and I got this message
I tried multiple times with the same result.
I then deicided to unistall using the following instructions.
MAC
Uninstalling
1. Move the Autodesk Fusion 360 and/or Autodesk Sim 360 dock icons to the trash.
Clearing your cache files
2. Start a new Finder window.
3. In the Finder Menu (Apple bar on top), select Go > Go to Folder
4. Enter ~/Library in the dialog that comes up
5. Browse to Application Support/Autodesk/and move the following folders to the trash:
- Webdeploy
- Web Services
- Autodesk Fusion 360
- MC3
- Synergy
- NINVFUS (if present)
- Neutron Platform
- Common
- Autodesk Sim 360 (if present)
- NSIM (if present)
6. Next navigate to $TMPDIR/Autodesk (open a Terminal window, and
type:open $TMPDIR/Autodesk) and move the following folders to the trash:
- Autodesk Fusion 360 and/or Autodesk Sim 360
- BrowserCache
- Neutron Test Application
- Project Forge (if present)
- Project Simulus (if present)
After downloaiding from the website to reinstall I keep getting this error. Please Help!
Sorry to hear about the update troubles. Can you attached the Autodesk.webdeploy.streamer.log file that the error message is referencing? This may contain information that will help to troubleshoot this issue.
Please forgive my ignorance but im not sure how to get that log info at this point.
Go to a Finder window and browse to ~Library/Logs
There looks like there's a link in the message center. The exact directory is also referenced in the warning itself, albeit the window could be resized to make it easier to read.
I hope that helps... Let me know if you are still having trouble finding it!
The whole file is huge and I cant paste it here (Max 100,000 characters) this is the bottom portion, does this give you the info you need?
2015-01-30 09:44:31,297 - __main__ - DEBUG :: Resetting the standard streams
2015-01-30 09:44:31,297 - root - DEBUG :: Preparing to do final log configuration
2015-01-30 09:44:31,297 - adsk.dls.streamer.configuration - INFO :: Setting deploy stream to production
2015-01-30 09:44:31,297 - adsk.dls.streamer.configuration - INFO :: Setting target app id to 73e72ada57b7480280f7a6f4a289729f
2015-01-30 09:44:31,298 - adsk.dls.streamer.platform - INFO :: Instantiating osx platform object
2015-01-30 09:44:32,401 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2015-01-30 09:44:32,401 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2015-01-30 09:44:32,402 - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f
2015-01-30 09:44:32,402 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/97e6dd95735340d6ad6e222a520454db/73e72ada57b7480280f...
2015-01-30 09:44:32,565 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.BeginProcess" args: ['2.0.1407', '73e72ada57b7480280f7a6f4a289729f']
2015-01-30 09:44:32,773 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Deploy.ConfigureApp" args: ['2.0.1407', '73e72ada57b7480280f7a6f4a289729f']
2015-01-30 09:44:32,914 - adsk.dls.streamer.process - WARNING :: Error detected, removing incomplete packages
2015-01-30 09:44:32,937 - adsk.dls.streamer.process - INFO :: Package with checksum ad4c375bcd4cf5757aabf5f00e96575e12bdd3f8 detected on system skipping install.
2015-01-30 09:44:32,937 - adsk.dls.streamer.process - INFO :: Package with checksum 7b99f02775666dc4ebbeb0979ddc19c1e4bc063b detected on system skipping install.
2015-01-30 09:44:32,938 - adsk.dls.streamer.process - INFO :: Package with checksum 3c591c8b2bff37f8adc48a255af5c3c39e8bf190 detected on system skipping install.
2015-01-30 09:44:32,938 - adsk.dls.streamer.process - INFO :: Package with checksum abff810c27054ea2282e3f192f20ce1a8cb6c0c6 detected on system skipping install.
2015-01-30 09:44:32,938 - adsk.dls.streamer.process - INFO :: Package with checksum d199d44859e9c0c57e2bedabbd27f1202831aedb detected on system skipping install.
2015-01-30 09:44:32,939 - adsk.dls.streamer.process - INFO :: Package with checksum 8c5858403aaf717d5052d5f16ce79eb9f4fda366 detected on system skipping install.
2015-01-30 09:44:32,939 - adsk.dls.streamer.process - INFO :: Package with checksum 899ae1be8bcf95b9a6fc3777e0c2886032bca19a detected on system skipping install.
2015-01-30 09:44:32,939 - adsk.dls.streamer.process - INFO :: Package with checksum 873af22a90ac88066f05725f09bf03b67b266ffc detected on system skipping install.
2015-01-30 09:44:32,940 - adsk.dls.streamer.process - INFO :: Package with checksum d32726694da146244835b7a7040d49f850d17ad9 detected on system skipping install.
2015-01-30 09:44:32,940 - adsk.dls.streamer.process - INFO :: Package with checksum a4f73e77a9e35ed359b380cd3a260d0fc4ebbfb1 detected on system skipping install.
2015-01-30 09:44:32,940 - adsk.dls.streamer.process - INFO :: Package with checksum 059f3cd9c47153869879c48ff8bff10e1d92401a detected on system skipping install.
2015-01-30 09:44:32,941 - adsk.dls.streamer.process - INFO :: Package with checksum 9377a14721879caf16692bb6ddd73c9ff44a875a detected on system skipping install.
2015-01-30 09:44:32,941 - adsk.dls.streamer.process - INFO :: Package with checksum 95a978eeb23201c3865c728be3b1884b0a24004a detected on system skipping install.
2015-01-30 09:44:32,942 - adsk.dls.streamer.process - INFO :: Package with checksum e6bbb6d99d7b3282f49cd68dc2769256fa799a7a detected on system skipping install.
2015-01-30 09:44:32,942 - adsk.dls.streamer.process - INFO :: Package with checksum 8954097fb6ed9dc6ac17bd9d4d42c242d24c4c53 detected on system skipping install.
2015-01-30 09:44:32,943 - adsk.dls.streamer.process - INFO :: Package with checksum 96d5984159a64fcb348fa08971dc673d5ed3f852 detected on system skipping install.
2015-01-30 09:44:32,944 - adsk.dls.streamer.process - INFO :: Package with checksum 470487882ca12f5b95aa2fbf22de2120b578924c detected on system skipping install.
2015-01-30 09:44:32,944 - adsk.dls.streamer.process - INFO :: Package with checksum 9c64a76082c7d31a9492875440b0f5e47548a904 detected on system skipping install.
2015-01-30 09:44:32,945 - adsk.dls.streamer.process - INFO :: Package with checksum 725f86d5948c0f249fc8e183fc2c7cadbb304bff detected on system skipping install.
2015-01-30 09:44:32,945 - adsk.dls.streamer.process - INFO :: Package with checksum a639e3df891ffa54e11c0896947bb0ad9c051519 detected on system skipping install.
2015-01-30 09:44:32,946 - adsk.dls.streamer.process - INFO :: Package with checksum 90d2c5b41f46dc8cb8cbcbdc6d17bcb5c89950b6 detected on system skipping install.
2015-01-30 09:44:32,947 - adsk.dls.streamer.process - INFO :: Package with checksum 47bc654e172acc7dc6ec6306a21a37705a0ac265 detected on system skipping install.
2015-01-30 09:44:32,947 - adsk.dls.streamer.process - INFO :: Package with checksum d5aaa792e22fae2de8f46c28246efe966112148f detected on system skipping install.
2015-01-30 09:44:32,948 - adsk.dls.streamer.process - INFO :: Package with checksum 7e4964539aa4b6d03fd7b79a3aade2a6c55d6729 detected on system skipping install.
2015-01-30 09:44:32,949 - adsk.dls.streamer.process - INFO :: Package with checksum 3e671a70ce0959c0fa498d39f1f43b9d37730666 detected on system skipping install.
2015-01-30 09:44:32,950 - adsk.dls.streamer.process - INFO :: Package with checksum b955f041231ff52b877beb7e90857e13d5701a49 detected on system skipping install.
2015-01-30 09:44:32,950 - adsk.dls.streamer.process - INFO :: Package with checksum 97384d2032e7b8dd26e195f1a8c78c624b17029d detected on system skipping install.
2015-01-30 09:44:32,951 - adsk.dls.streamer.process - INFO :: Package with checksum 6bbbd063519238baec7256a99bea5548d29d8e75 detected on system skipping install.
2015-01-30 09:44:32,952 - adsk.dls.streamer.platform - INFO :: Required OS version: <adsk.dls.streamer.manifests._ManifestList object at 0x107608250>
2015-01-30 09:44:32,954 - adsk.dls.streamer.process - INFO :: Pulling package manifest: 2f2bb806e661f4717fab7726059c45587f4c1367
2015-01-30 09:44:32,954 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/2f2bb806e661f4717fab7726059c45587f4c1367.js...
2015-01-30 09:44:33,058 - adsk.dls.streamer.process - INFO :: Downloading package from https://dl.appstreaming.autodesk.com/production/packages/2f2bb806e661f4717fab7726059c45587f4c1367.ta...
2015-01-30 09:44:33,143 - adsk.dls.streamer.process - INFO :: Extract path resolves to: /Users/SaintLawrenceTitle/Library/Application Support/Autodesk/webdeploy/production/283f47cb0eca637294957ba879067aecb2440930
2015-01-30 09:44:46,461 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to /Users/SaintLawrenceTitle/Library/Application Support/Autodesk/webdeploy/production/283f47cb0eca637294957ba879067aecb2440930/streamingsession.json
2015-01-30 09:44:46,518 - adsk.dls.streamer.process - INFO :: Activating configuration file at /Users/SaintLawrenceTitle/Library/Application Support/Autodesk/webdeploy/production/283f47cb0eca637294957ba879067aecb2440930/Autodesk Fusion 360.app/Contents/Resources/CONFIG/ApplicationOptions.production.xml as /Users/SaintLawrenceTitle/Library/Application Support/Autodesk/webdeploy/production/283f47cb0eca637294957ba879067aecb2440930/Autodesk Fusion 360.app/Contents/MacOS/Fusion 360.server.config
2015-01-30 09:44:46,520 - adsk.dls.streamer.utils - INFO :: /Users/SaintLawrenceTitle/Library/Application Support/Autodesk/webdeploy/production/283f47cb0eca637294957ba879067aecb2440930/Autodesk Fusion 360.app is an autolaunch target
2015-01-30 09:44:46,544 - adsk.dls.streamer.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "/Users/svc_p_bi/Perforce/Neutron/Streams/Projects/Neutron/ReleaseCandidate/src/Neutron/Installer/Streamer/src/adsk/dls/streamer/process.py", line 1184, in execute
File "/Users/svc_p_bi/Perforce/Neutron/Streams/Projects/Neutron/ReleaseCandidate/src/Neutron/Installer/Streamer/src/adsk/dls/streamer/process.py", line 1150, in execute_without_errorhandling
File "/Users/svc_p_bi/Perforce/Neutron/Streams/Projects/Neutron/ReleaseCandidate/src/Neutron/Installer/Streamer/src/adsk/dls/streamer/process.py", line 986, in _config_app
File "/Users/svc_p_bi/Perforce/Neutron/Streams/Projects/Neutron/ReleaseCandidate/src/Neutron/Installer/Streamer/src/adsk/dls/streamer/process.py", line 594, in _executetasks
File "/Users/svc_p_bi/Perforce/Neutron/Streams/Projects/Neutron/ReleaseCandidate/src/Neutron/Installer/Streamer/src/adsk/dls/streamer/osx/platform.py", line 513, in create_launch_items
File "/Users/svc_p_bi/Perforce/Neutron/Streams/Projects/Neutron/ReleaseCandidate/src/Neutron/Installer/Streamer/src/adsk/dls/streamer/manifests.py", line 419, in walk
File "/Users/svc_p_bi/Perforce/Neutron/Streams/Projects/Neutron/ReleaseCandidate/src/Neutron/Installer/Streamer/src/adsk/dls/streamer/manifests.py", line 441, in _walk
File "/Users/svc_p_bi/Perforce/Neutron/Streams/Projects/Neutron/ReleaseCandidate/src/Neutron/Installer/Streamer/src/adsk/dls/streamer/manifests.py", line 432, in _walk
File "/Users/svc_p_bi/Perforce/Neutron/Streams/Projects/Neutron/ReleaseCandidate/src/Neutron/Installer/Streamer/src/adsk/dls/streamer/osx/platform.py", line 505, in _dirvisitor
File "/Users/svc_p_bi/Perforce/Neutron/Streams/Projects/Neutron/ReleaseCandidate/src/Neutron/Installer/Streamer/src/adsk/dls/streamer/osx/platform.py", line 299, in addapp
FileExistsError: [Errno 17] File exists: '/Users/SaintLawrenceTitle/Applications/Autodesk Fusion 360.app'
2015-01-30 09:45:02,438 - adsk.dls.streamer.process - WARNING :: Error detected, removing incomplete packages
2015-01-30 09:45:03,515 - adsk.dls.streamer.registry - INFO :: Shutting down database connection
Can you attach the file to this thread?
See attached. I hope you are able to make sense of all this and sort through all the info here it is rather large.
This is a bit of a guess.. but, could you try going through the clean uninstall procedure one more time, but with one additional step?
The additional step is:
When launching the installer, make sure that it is the latest installer from Fusion360.Autodesk.com.
Before launching the installer, double check the activity monitor and make sure that there are no instances of Fusion 360 or streamer running in the background.
Let me know if that helps. If you get another error, please repost the updated log file.
Thank You and Best Wishes!
