in the past i often copy/pasted components from one open drawing to the other to reuse previously designed components. That always worked well.
I didn't do so much work with Fusion360 lately but before i stopped working with it i already had these crashes when doing these copy/paste actions. Now after restarting to work more with Fusion again i still see this error. Is there any general problem?
I also sent 2 CERs from two times that happened with the same file today.
Frank
Solved by Helmi74. Go to Solution.
Hi Helmi,
this seems to be similar to this: http://forums.autodesk.com/t5/general-fusion-360-questions/fusion-crashing-on-pasting-new-component-...
Please, could you try a workaround described here: http://forums.autodesk.com/t5/sketching-sculpting-modeling-and/duplicating-or-copying-components/m-p...
Josef
