Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Show only
Search instead for
You should be able to extract the Composite install from the Maya SP1. Not sure why the Maya SP1 is such a larger install, though. Not sure if that may or may not break anything though.
