We've got the new intuos pro tablets, running 2015 on z800's. Problem is the touch mode turns itself on occasionally. Local support has altered the xorg so that the pen doesn't work as a touch signal, but the tablet is still active. Is there a way to turn off touch in linux?
Solved by Beau_James. Go to Solution.
Comment out the 'touch' entry in your /etc/X11/xorg.conf near the top, like:
# InputDevice "touch" "SendCoreEvents"
and then reboot -- unless that's all support did, I'm not sure what you mean exactly by 'so the pen doesn't work as a touch signal...'
Thanks for the suggestion but unfortunately that didn't work. The tablet would stay on "touch" and when you brushed your hand across it interfere with Flame.
Local support came back in and adjusted the PAD & TOUCH settings in xorg as below
This worked and disabled the touch function completely.
I'd love to be able to program the buttons to be hotkeys in the future.
