Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
Turn off touch mode on Intuous Pro
5 REPLIES 5
psjvfx
7832 Views, 5 Replies
We've got the new intuos pro tablets, running 2015 on z800's. Problem is the touch mode turns itself on occasionally. Local support has altered the xorg so that the pen doesn't work as a touch signal, but the tablet is still active. Is there a way to turn off touch in linux?
PSJ
VFX Supervisor
FSM
5 REPLIES 5
ManChicken
in reply to: psjvfx
Comment out the 'touch' entry in your /etc/X11/xorg.conf near the top, like:
#  InputDevice "touch" "SendCoreEvents"
and then reboot -- unless that's all support did, I'm not sure what you mean exactly by 'so the pen doesn't work as a touch signal...'
Bob Maple | idolum
psjvfx
in reply to: ManChicken
Thanks for the suggestion but unfortunately that didn't work. The tablet would stay on "touch" and when you brushed your hand across it interfere with Flame.
Local support came back in and adjusted the PAD & TOUCH settings in xorg as below
This worked and disabled the touch function completely.
I'd love to be able to program the buttons to be hotkeys in the future.
PSJ
VFX Supervisor
FSM
aldy
in reply to: psjvfx
Reinstall the DKU and reboot usually works for me. Or just reboot after you plug the new tablet device if the machine was turn on.
By default, touch mode is set to off by the DKU installer.
Beau_James
in reply to: psjvfx
open the /etc/X11/xorg.conf file and look for the following section : -
Section "InputDevice"
Identifier "touch"
Driver "wacom"
Option "Mode" "Absolute"
Option "Type" "touch"
Option "Device" "/dev/input/wacom-touch"
Option "USB" "on"
# Option "Rotate" "HALF"
# Option "ScreenNo" "0"
# Option "TwinView" "horizontal"
Option "Touch" "off"
EndSection
In the second last line, if Option “Touch” is set to “on” set it to “off” and restart the graphics or reboot the system.
natasha.doria
in reply to: Beau_James
xorg.conf
