Can I request that timeline zooming to be consistant with workspace zooming while using the cntl-alt hotkeys.
if you hold cntl-alt and left click over a viewer or schematic, the UI zooms in when you drag to the right.
if you hold cntl-alt and left click over the timeline, the UI zooms out when you drag to the right.
This is muscle memory hell.
Also the zoom sensitivity seems much less on the timeline than in work spaces. For example, I need to use multiple swipes to get to the zoom level I require.
Many thanks.
Solved by Robert.Adam. Go to Solution.
Hi Andy,
I have logged an improvement request and added your name to it.
Thank you for reporting this!
Best regards,
robert.
