Choosing the correct sync for a project
Summary
A Sync Pulse Generator (SPG) produces synchronization signals with a high level of stability and accuracy.
These devices are used to provide a ‘master’ timing source for video facilities.
Autodesk systems require a valid sync connection in order to function correctly.
Why do Autodesk Applications Require Sync?
Sync ensures frame accuracy between the various video devices.
Sync ensures video / audio remains synchronized.
Sync ensures we get the desired results on the preview device.
Required Types of Sync Sources
Use one of the following types of sync for your project:
Bi-Level for Standard Definition Projects.
Tri-Level for High Definition Projects.
Heres the Autodesk Link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9242618&id=15490815&siteID=123112
