Hiya,
It's been a while since you've posted, asking for advice on specs for a Dell machine optimized for workflow in Mudbox. I'm curious how you came out, thanks for sharing specs if you will. I have two machines, neither of them behaving well with Mudbox (and Meshmixer), Maya and ZBrush work fine, just these two programs cause major issues locking up on fbx and obj files with just over 4 million polys, which I'm seeing is super low, should be able to handle that fine.
machine 1: Windows 7 Professional, Intel (CR) Core (TM) i7-3770K CPU @ 3.50 GHz 4.50 GHz, 16 GB RAM, 64-bit
machine 2: Mac Pro, Dual Intel Duo Core upgraded to 8-Core, 2.66 GHz, 16 GB RAM, OSX 10.7.5
Thanks, if you can share your specs and what's the max poly count you're working with effortlessly in Mudbox.
Best,
Benjy
I know more VRam the better, is a Geforce Titan other then the price, really needed ?
