Hello everybody
i have a question adding subtitles to a final sequence in flame.
the company that make subtitles, send me usually a xml wth the subtittles, they make this xml in final cut and also they change the font size the position and some other properties.
when i imported the xml i have the text but none of the properties load in the xml (text,font,size), so i have to do all this manually.
what is the usual workflow for adding this xml
thanks
Diego
We create a style in Flame (used to be on Smoke) and save it to a location OUTSIDE the project.
Then we use Notepad ++ to REPLACE the following in the XML
<setup></setup>
to include the font location we created
<setup>/usr/discreet/subtitles/Arial_50.ttg</setup>
This is what Grant was talking about. It works great on all Western languages.
Paul
If you need to throw this to burn and you are getting issues with missing fonts or the font gets substituted by the deafult. Instead of copying your entire font library to the nodes, you can just symlink the directory holding the fonts on the flame to the burn node or visa versa through an nfs mount or going directly through /hosts/. Basically point the burn directory /usr/discreet/font/ -> the /usr/discreet/font/ on the flame.
Hi!
We have the same problem here, usually I have to scale and change the font manually. Is there a way to load the XML completly without this problem?
Have a nice day!
Hey Jose,
if you look at my previous post, you can see how to change the font in the XML (I think I gave step by step instructions clearly), but let me know if you need it explained a bit more.
You can also do the Vertical & Horizontal offset in the XML too, but it takes some playing around to get it right.
Grant, what is different in the XML import between Smoke & Flame? I noticed that the V/H setup does not work from my Smoke settings. Anything in particular I should look for?
Paul
Yeah!
I read it, just need a little bit of explanation in the scale an positiong values in the XML.
Thanks!
Well, you set up ALL that in the Flame (Smoke) first. You just go in and type in some random text and set the size, the border, color and save that as a setup/template. But save it somewhere OUTSIDE your project. Note where that location is and when you go into the text tool (like Notepad ++) you do a find and replace for the setup like so:
<setup></setup>
See how we placed our designed font outside the project path? That way you can use it for ALL projects. In the case I have here, we created an Arial font at 50 points, all the border and color is saved too.
Let's see what Grant says about the offset (which is also in the XML that you can replace). You may want to look up in the manual about saving font styles.
Does that help a bit more?
Wow Grant. Thanks for the info.
I just want to make sure that we're talking about the same thing. Reading your info, it looks like you are talking about a project created in FCP that includes text. Am I mistaken?
What we're talking about is when a company creating subtitles in another program that can save in an FCP XML.
OR are we discussing the same thing?
Cheers!
Paul
Thanks Grant, but we've been doing subtitles for a few years now on Smoke/Flame.
I was just trying to help out some people here that may not be using, or have access to FCP.
Cheers!
Paul
Hi, Grant!
If somebody still interested and do subtitles a lot, maybe good idea to look at TitleExchangePro
http://www.spherico.com/filmtools/TitleExchange/
They have tool to convert to different formats include STL, FCP XML, AUTODESK SMOKE XML
