I´m using Mudbox for a project and I always getting strange brushstroke results when I´m getting down to detail level. They are not straight but blobby. And another strange thing happen when I look at the wire frame of my model, it looks strange not even, this happen not on every model, but on this I´m working on.
Would be great if someone could help me!
Best Regards,
Josef
Solved by JosefSL. Go to Solution.
Thank you Robin, so that would explain the meshdisplay. But about the strokes, the stamp spacing is turnt of, it´s just like that mudbox reacts to sensetiv on the pressur of the wacom pen.
No I found out, taking the hook out off meshspacing make the things worse, but leaving it on and turning it to zero gives me better results, another thing is, if I do fast strokes the stroke gets much more even and less bumpy, if I do slow strokes they get more spaces in them.
Thank you Robin, that option is interesting and I played with it, but now I found someting out that I didn´t mind off, I have used to high settings for the brush strength in the default settings, so the result was to much pressur deependend, now I use the maximum value I really need and not higher and it works fine! But thank you for stopping by to help me!
