Im using the 2015 Ext 1 Smoke, and have the latest Sapphire Sparks installed.
Adjusting a setting in a Spark node caused a crash, and now i cannot restart that Project - it just keeps trying to initialise the knackered spark and crashes again.
Is there a way to start a project without initialising the Spark?
Any suggestions how to get around such problems when they occur?
thanks
Adam
Solved by BKM. Go to Solution.
Best thing to so would be to contact support and see if there is a backup of the project they can get to.
I wrote a blog about it if it helps....
http://www.premiumbeat.com/blog/how-to-use-project-backups-in-autodesk-smoke/
thanks Brian - I had just found your article when your answer came through....sounds like its exactly the info i need
thank you very much!
adam
my bacon is now well and truly saved.
Thanks for the walk through Brian - really good info, well explained.
adam
Not a probelm.. glad it helped.
