Hi all,
As the title says, is there any solutions yet for this issue? We have Smoke with network license.
and License Server won't start on OSX 10.8 due to a defect in OSX.
The full KB is here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21280818&linkID=9242618
I just wondering what should do if someone buy a new Mac (which comes with OSX 10.8+ already) and have Smoke with NLM. I think OS Downgrade is the only option
I appreciate any advices.
AW
Solved by Robert.Adam. Go to Solution.
Hi Aldy.
I'm sorry to hear you are experiencing this issue.
If the solution in the KB article does not work, please call our Licensing support team at 1-800-551-1490 to get a license for your Mac's other network port. (the one that has become the default port).
Robert.
i don't think its a solution, what have been said in the kb article, because on every reboot there can be a new primary ethernet port on osx10.8.
but what about the possibility to licensing both ports? its still one machine smoke would be running on.
Hi Robert,
Sorry late reply,
Thanks for your advice. Our team will try to contact Licensing support team.
AW
