Hey guys.
I'm working on a decently simple video, and I have come across a seemily simple problem that is making me feel stupid.
I can't figure out how to import songs from iTunes.
I've used many other editors, but am a bit of a newbie to Smoke. Help would be much appreciated.
Thanks in advance!
/SnP
Solved by grant.kay. Go to Solution.
I'd probably do something like:
Check my itunes import settings are set to AIFF 48kHz
Right click on track and convert to aiff
Then right click on the newly created track and 'show in finder'
Drag into smoke.
But there are probably other ways
You can no longer convert your track into anything useful using quicktime, Apple have removed that feature from itunes. Now you have to change the way iTunes works. Set you convert preferances then re import the file.
http://support.apple.com/kb/ht1550
'import settings' can be found by looking under 'itunes preferences' - general tab. It's at the bottom next to 'when a cd is inserted'
Yes it doesn't say 'convert' - it's 'create'. The right click menu should say 'Create AIFF Version'. If you had set the import settings to wav then it would say 'Create WAV version'.
I think there are automator scripts/services to do things like export to certain folders in specific formats but I've not used them.
To find the complete path, you can Alt-click on the folder name that is displayed in the middle of the Finder's dialog window title bar.
That being said, you don't have to find the path. You can simply drag and drop the file from the Finder directly to Smoke's Media Panel.
Cheers,
Jasmin
To import music from iTunes to Smoke or other video editor, you need to convert the music files to plain audios first as iTunes music are in special format which can't be directly used. So, to do that, you can use the tool like iTunes Music Converter, etc. to convert iTunes music to common files and then you can put iTunes music on other platforms with ease.
I think this is the best and easy way:
If you want to import iTunes Music to Smoke, you need to convert the downloaded iTunes M4P Music to MP3 format. Have you tried the AMusicSoft Apple Music Converter? Now I am using it with its free trial. With AMusicSoft Apple Music Converter, you can convert songs without loss of quality in minutes.
