Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
SMOKE 2012 won't start
1 REPLY 1
214 Views, 1 Reply
i got this message "Please ensure that your license server is running and configured with a valid license.
You can also select a remote network license server (see next screen)."
If i use the License Server Configurator the Server Status is Stopped. If I click start, after a long pause i get:
"Unable to start the license server."
Service Monitor gives a similar result. Every Status is green, exept for License Server (ADLM) which has a red status circle.
Had this problem before, and I solved it by changing the hostname to "127.0.0.1" but it happened again after a week.
Hostname is still the same.
This is very frustrating. does anyone have an advice on this topic?
1 REPLY 1
jaseo
Here is some help on license server issues.
http://usa.autodesk.com/getdoc/id=TS16129770
copy and paste the following so that we can verify a few things -
/var/flexlm/autodesk.lic
/usr/local/flexnetserver/adsk_server.lic
the output of 'ifconfig' (run in terminal)
thanks
Jason
