Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
slipping multiple clips
1 REPLY 1
amx001
456 Views, 1 Reply
how can i slip multiple clips on the timeline, without moving the cut points? Currently slipping multiple clips only works if the clips are not touching each other. If they are indeed touching then the clips are slipped but so too is the edit point. If they are separated by a clip that i do not include to slip, then slipping works the way I'd expect ..this function used to work well in smoke2013
1 REPLY 1
fred.warren
in reply to: amx001
It is no longer possible to Slip multiple segments at once without moving the cuts. You have to slip all clips individually.
This is a regression we are aware of and we'll do our best to correct the situation rather sooner than later.
fred
Frédéric Warren
User Experience Designer
