I'm trying to edit 1 sequence (partial tracks) into another. I have my main seqeunce loaded up and my other sequence in the source (left side) in timeline view. I patch video track 2 of the source to video track 3 of my record sequence. Fine so far. Then I patch track 5 of the source sequence to track 4 of the record sequence. Track 4 is patched but source track 2 has now changed to source track 3 (still routed to track 3 on the record side). No matter what I patch, the first one sticks and then changes when I patch a second. Am I missing something? This seems pretty basic.
Greetings Ken,
This should assist in your quandary:
Timeline Editing: Track Patching
Sequence Patching - Audio Tracks
Sequence Patching - Video Tracks
This and many more tutorials are available on the Smoke Learning Channel to help with your questions.
Also keep note of where your playhead and primary indicator are. Also make sure no tracks are locked.
Thanks. I got single track patching. The issue I was having was if I had a sequence loaded on the source side with 4 video tracks and a record sequence with, lets say 6 video tracks. I want to patch Source V1 to Rec V3. I also want to patch source V2 to Rec V4, Source V3 to Record V1 and Source V4 to Rec V5. Whenever I patched the first track it was fine. As soon as I assigned a second track patch, the first one would change.
Yes, I was doing that but certainly not effictient, especially if you have 10 or 12 video tracks in your sequence. Not enough track real estate.
