Screencast video recording now available for Fusion 360
13 REPLIES 13
Message 1 of 14
EricStover
10941 Views, 13 Replies
Fusion fans, check out the Gallery page- notice a new tab? It's a new video capture service which let's you create a Screencast which showcase how you accomplished a task, a workflow, even a full design. There is a Windows and Mac version and you can record, post, and share anything. With Fusion 360 - you'll notice we also capture a timeline of all of the buttons, dialogs, and menus that were used during the recording. This information really helps others understand exactly what was done to accomplish a particular task. We hope you enjoy this new, free service for Fusion 360 and many other products. The direct link is: https://screencast.autodesk.com/ The free recording utility is located here: http://www.autodesk.com/screencast-download Thanks! - Eric Stover, General Manager/Autodesk Screencast
Eric Stover
General Manager- Screencast
1 Market Street, Suite 200
San Francisco, CA 94105
13 REPLIES 13
Message 2 of 14
Helmi74
in reply to: EricStover
This is amazing news, Eric - thanks.
Screencasts definitely are the present and future of online learning for software and other computer related stuff.
Frank / @helmi
Established 1974. Internet addicted since 1994. Collector of Kudos.
Message 3 of 14
TheHangman
I am wondering what I am doing wrong.
So I have tried several times to install and reinstall Screencast over and over. But the problem is that my Screencast is not capturing Fusion 360 tool bars as it should. Looks like I am being selfish and modelling something in the dark so that others don’t see what I am doing. Very awkward! as it works well for Alias and Inventor
Does anyone know what could be the issue, or better the solution for such issue.
Here is how the video comes out.
https://fusion360.autodesk.com/projects/cloth-peg-torsion-spring-knowhow
Cheers
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
Message 4 of 14
EricStover
in reply to: TheHangman
Hi - the Screencast team will reach out to you (today) privately on this issue to help diagnose it. Sorry about the trouble!
-Eric
Eric Stover
Message 5 of 14
ram.mummidi
I believe you used link https://screencast.autodesk.com/Embed/b174d368-2bc2-43c6-a200-d98f2206c697 to post to the forums instead of the link https://screencast.autodesk.com/Embed/Timeline/b174d368-2bc2-43c6-a200-d98f2206c697.
If you look at your actual Screencast:
https://screencast.autodesk.com/Main/Details/b174d368-2bc2-43c6-a200-d98f2206c697
this has all the commands listed.
When embedding you have the option to embed just the video or the vidoe with timeline. Please use the link with Timeline in it, to see the commands.
Hope this helps!!!
Thanks, --Ram
Ram Mummidi
Principal Engineer
Message 6 of 14
TheHangman
in reply to: ram.mummidi
Hi and Thak you both for the prompt reply.
@EricStover looking forward to have an assistance in th
thanks anyway to point out the differences about sharing the command line, I do understand how to go about the embed files and so on, but my issue here is that on my videos is not showing the software toolbars in anyway. I don't think its Fusion 360 as work perfectly on Inventor and if I remenber in Alias.
Looking forward to have a resolution on this matter, as I need to produce some learning material.
All the best.
Message 7 of 14
innovatenate
I just moved a post by @jjurban55  to the Screencast forum for this particular issue.
http://forums.autodesk.com/t5/screencast-general-discussion/screencast-anyone-know-why-stuff-not-bei...
Are you using any high resolution monitors (5K), dual monitors? Does it make any difference if your record on one monitor versus the other?
In Inventor, the ribbon can be sensitive to text scaling. Perhaps this issue is similar?
In Control Panel\All Control Panel Items\Display, is the text size set to 100%?
Are you using any custom text size in the DPI settings other than 100%?
I hope that helps. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
Message 8 of 14
bagchis
@TheHangman Thank you for the reply. Would you have some time for a quick phone conversation for us to debug the issue? Please send me your availability for today/tomorrow along with the best number to reach you at. You can email me directly at shibai.bagchi@autodesk.com
Look forward to hearing from you.
Shibai Bagchi
Product Manager, Screencast
Message 9 of 14
TheHangman
in reply to: innovatenate
Hi
I have all the Windows setting as default, and thanks for the link I have seen it but as I could not find an answer for my case on Screencast community at the time
i though to bring it to Fusion 360.
Anyway, as a matter of the fact my settings are:
and I just sent an email to
Message 10 of 14
ram.mummidi
Do you have Transparency enabled? If not, here is how you enable it.
- Right click on your windows desktop and select Personalize
- Click on Window Color (at the bottom)
- Enable transparency (check box - enable it).
Also a video on how to do it here: http://www.tomshardware.com/faq/id-2066988/enable-window-transparency-aero-windows.html
Without the transparency enabled, some of the overlays aren't applied.
Also make sure, Desktop Composition is enabled. You can enable it with this steps in the following link:
http://www.sevenforums.com/tutorials/127411-desktop-composition-enable-disable.html
If desktop composition and transparency are already enabled, we would need to get more information on what is different on your system.
--Ram
Ram Mummidi
Principal Engineer
Message 11 of 14
TheHangman
Hi
Thank you for the advise, I have just downloaded right now and re installed it over again and Run as Admin, but this time I did as set up as custom and I only tick off add in for Revit.
Also, I did refresh my Windows Experience Index > the values did not change but something behind the scene has happen and now it seems to be working. AH! I also change the
compatibility mode to Win Vista SP2
Thanks you all.
Message 12 of 14
EricStover
Great - glad to hear that solved your issue. Let us know if you have any further issues and thanks for using our Screencast service!
(Thanks Ram for the quick diagnosis and turnaround.)
-Eric
Eric Stover
Message 13 of 14
TheHangman
Now I am trying to break the toy to see if I find out what exactly happen.. As I chenged several settings in one go I am not sure what can cause the issue.
But if I find out more information I keep you guys posted.
Thanks again.
Message 14 of 14
mark33.in.oz
I've (I hope) installed the screencast thing and am wanting to check the settings.
As per post I am trying to get to the highlited part....
As you can see, there is no DISPLAY option.
I'm new to Windoze10.
Sorry folks, I know it is more a windoze problem than a F360, but.......
It took me 10 minutes to get to there, because I didn't know you have to select the ICON view mode to get that kind of view rather than the "default" one, which doesn't show all the items.
