Solved by vkshah. Go to Solution.
Couple things come to mind; Besides possibly wanting to crop the edges of the screen's matte by a couple pixels and actually blur the edge to work it into the composite (depending on the sharpness of the footage):
. In the Output tab of Action, make sure Anti-Aliasing is turned on
. You might turn up the software AA to a few more samples in the Node Prefs menu of Action
. Keep in mind while you're in Action things might look a little crunchy regardless of what you do, until you render (or hit the Preview button to see what a frame really looks like)
