I have an edit that i have done using MXF files imported directly into Smoke. I have not applied any LUTS to improve the very washed out colour, and have finished the rough cut with just a few timewarp effects.
I now need to send the project to Resolve for grading, but i cannot get my head around the workflow. The only tutorial i have found transcodes the edit into ProRes - which seems very counterintuitive if you want to retain all the log colour data.
I have tried to export edls without any media, but i am constantly seeing Smoke trying to render the entire timeline before exporting...even though i have told it not to include media!
the cut is 90 seconds, but the renders are taking over 30minutes! Surely this is not right?
I am unsure what to do about the timewarped clips - i assume they will need to be rendered, but into what format and how do i export just those clips and not the entire timeline?
where on earth do other editors go to learn all this?
adam
Solved by BrianBuongiorno5346. Go to Solution.
I have not found a simple round trip to Smoke-Resolve workflow either. What I did find was that Smoke would crash when I tried to open an XML from Resolve. If I opened in FCP7 first, made a new XML from there, it would open fine in Smoke. This could very well be a Mavericks issue, so it's hard for me to troubleshoot any of this.
KEN
