Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
reverse atlas
5 REPLIES 5
1307 Views, 5 Replies
reverse atlas
Hello every one, i have an fbx 3d model on unity 3d delivered with other models. all of them share a big atlas texture. I'm trying to "break the atlas" on 3ds max to get only the texture i want. I don't have the plist neither.
i'm a developer and don't know that much about 3ds max so please bear with me on this.
thank you.
Tags (1)
5 REPLIES 5
Steve_Curley
Sounds like what you want is the Render to Texture feature. That will create a new image containing just what is necessary for that particular object. It's not too difficult to use (check the Help for details of how to use it) - post back if you need anything further on it.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
in reply to: Steve_Curley
Hello and thank you for your reply, i usesd this tutorial
https://www.youtube.com/watch?v=Xi467BO_-JY
to understand what to do with render to texture, but here he is baking 5 seprate textures into one big texture.
Actually what i'm looking for is the other way around.
i have 10 animals and 10 textures baked into 1 big texture. I need to use only one animal et therefore i need to extract the correspending texture from the big one.
Hope this is clear
thanx
Steve_Curley
It's the same thing, actually. If you have a model with multiple materials it's a lot more efficient to create a single texture from many. Now, that might seem backwards, but if there's only 1 material (but the model is only using part of it) the RTT procedure will create a new image containing just the necesssary part of the "atlas" image, which is what you're after. It's the same process either way.
Max 2016 (SP1/EXT1)
Yes, actually i tried it and a got 1 texture with only the information i needed and a smaller size. What confused me i guess is that i was waiting to get a single texture like any other non baked model.
thanx alot this was very helpful.
Steve_Curley
You're welcome 🙂
Max 2016 (SP1/EXT1)
