Hi everyone!
I'm trying to figure out how to properly archive projects and be able to recover them in the future. As far as I know and I've tried, when you have your project archived and you restore it, Smoke creates the project in the same folder it was created the first time, right? Do I have the option to select another folder for creating the "new" project from the archived one?
I'm using Smoke 2015 SP3
Thanks in advance!
Solved by moreymichael. Go to Solution.
When you unarchive the job, you first create a new project, with whatever settings & names you want. You open the archive, select the elements from the archive you want, or everything, if you like...then drag the selection into the media library. Press the Restore button, and it will load into your new job.
Hope this helps.
