Unfortunately, this behaviour is "normal". The simple gesture of selecting an Action node invalidates its render.
fred
workaround - dupe the sequence and check your settings there. if all is good, delete the dupe and no need to rerender again.
So, the $64 question: Is this considered to be a problem? IE, will it be fixed?
It is indeed something that could be improved, but it is not possible for us to say if it will be fixed or not in the future.
fred
Duping a timeline is pretty trivial. Especially if it keeps you from having to rerender a ton each time.
