Great video. Thanks for making these.
One question though. We recently upgraded to extension 2 and the shape tracker in action is gone. I have been told that the planar tracker is its replacement. Is this correct?
Thanks for the helpful reply.
I tried out the mutli-feature detection today and I am not getting nearly the same great results I was getting with the "shape tracker" from extension 1. Is it possible the algorithim has changed? Also the nice blue boxes have gone away as well.
Thanks.
Hi Grant,
This is not strictly on subject, however this was the closest thread I could find to my problem. We just upgraded to extension 2, and I was very excited to have Mocha style planar tracking built right into the box. The tracker seems to track quite well, however, I use planar tracking alot for clean up work and I am running into one problem I can't figure out.
When I use the planar tracker with a gmask attached to isolate the region I want to track, the axis I am applying the tracking data to no longer allows me to "adjust offsets". This is troublesome because let's say I painted a clean frame on frame 12 of the shot. I need all my axis settings at default (scale= 100, Position x=0, Position y=0 etc) on frame 12 so that my clean frame lines up perfectly. I can not figure out how to make this happen. Am I missing something?
Kyle
I believe this happens because the workflow has changed a bit with the way data works within the node.
This is how its now done. (I will make a video on this at some point )
I have laid it out in point form but its actually very fast to achieve this .
Hope this helps.
Regards
Grant
Here is a screenshot of my nodes when I performed the method above.
I used a matte input with my clean frame but you could have also used an action gmask attached to the image input if you want to do the roto-work in Action at the same time.
Regards
Grant
