Please can someone advise me the best way to go regarding importing mxf files and xmls.
I will first off admit that xml's, mxf and Smoke are all very new to me. I have worked almost exclusively on FCP7 and ProRes for the past 8 years!
How do i import a Sony F55 mxf file into Smoke?
I have tried to follow the User Guide, but the results i'm seeing are definitely wrong! The raw file is very washed out, as i would expect, yet when i try to import using the LUTs as described in the User Guide, the image becomes even more unusable - perhaps becuase the Manual suggests using "Sony-Raw_to_SLog2 from the camera/Sony/ directory in the Autodesk location." - yet there is not a file with that name in that folder.
Also - is it better to import the raw mxf files to edit with, then transcode to a different colour space to finish?
thanks
Adam
Follow the steps below
1.Mediahub tab
2.enable show all formats ,select sony raw in menu
4.down to tat from the menu select resolution and it ll be standard , select to high.
5.And select color in the midle menu , select s-log2/ S-gamut
regards
saravana.S
