I have a computer in class that I work on that has Mudbox 2016 and the Ext 1, but on my personal computer I don't have the Ext. Where can I get the Ext? I need it because when I try to open up projects that I have been work on in class on my personal computer it says that the version that I save with is newer and so I can't open up the file or do anything with it. Can I download/install it? If its really obvious then I'm missing it and would appreciate any help that can be offered. Thank you!
Which version of Mudbox do you use? Student version or commercial ($10/month)?
In Mudbox, if you click on the Help menu at the top, there is a Check for Updates option. Does it have an option for you to upgrade? If you are licensed (either as a student or commercially) it should allow you to update.
