Hi folks,
I'm brand new to Linux, so please bear with me. I need to mount a windows NFS shared folder on my Flame system. I am entering this basic string in the console to accomplish this, and I think I'm close, but am wondering if I have the protocol correct.l..ie,. all the spaces and commas and such are correct, as well as the calls. Anyone familiar see a problem here? Anything missing? Any help would be greatly appreciated...
# mount -t cifs -o username=<username> , password=<password> , domain=<domain name> //<WIN PC IP>/<sharename>/mnt
Shannon, long time no talk 😉
take the spaces out before the commas
put a space between the share and your mount point. So instaed of <sharename>/mnt make it <sharename> /mnt.
Also, don't mount to /mnt. make a directory in /mnt and mount to there like mkdir -m 777 -p /mnt/samba
and mount to /mnt/samba
let me know if that works. if not i'll look over the string a little more and see if I see an issue with your info. Also, what error are you getting.
Also...https://access.redhat.com/solutions/448263
Beau
As Beau says, yours should look more like:
mkdir /mnt/sharename
mount -t cifs -o username=foo,password=bar,domain=blah //winservername/sharename /mnt/sharename
filling in all the foo/bar/blah/winservername/sharename as approriate.
However I configure it from /etc/fstab so I can just do "mount /mnt/sharename" and not have to remember everything else or write a separate script to do it. First making sure /mnt/Spark/Jobs already exists (mkdir as root once first), my fstab looks something like:
//spark/Jobs /mnt/Spark/Jobs cifs credentials=/root/.cifs_creds,uid=bobm,gid=users 0 0
uid/gid is my username/group I login to the Flame workstation as so that files/dirs all look like they are owned by me.
/root/.cifs_creds contains:
username=bobm
password=whatever
This way my server password is in a protected file owned by root rather than in world-readable fstab.
Then as I said it's just a matter of doing "sudo mount /mnt/Spark/Jobs" when I need it.
I just made a user account on my windows box called test with the password test. Then I shared a folder names Movies. I then added that user named test to the share with read and right access.
Then from flame I typed the following:
Mkdir –m 777 –p /mnt/test
Mount –cifs //ipaddress/Movies /mnt/test –o username=test,password=test
Obviously, i left out the domain since i am on a test box. And it mounted right away. give it a try
try that, if not if you can get me a teamviewer session up on the win box and the flame, i can jump on when i'm off this case.
Quick correction.
should be
mount –t cifs //ipaddress/Movies /mnt/test –o username=test,password=test
