Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
matchbox Switch node?
3 REPLIES 3
theonlyandyt
818 Views, 3 Replies
Has the switch matchbox been removed? I can't find it on this intallation (2015)
Is there an alternitive?
Many thanks
MacBook Pro Retina, 2.7GHz Intel Core i7, 16GB RAM, Thunderbolt 2 R6
Tags (2)
3 REPLIES 3
myeffigy
in reply to: theonlyandyt
You are right, it seems to be missing.
You can take the glsl files from 2012 and drop it into the matchbox directory. When accessing matchbox in cfx, you will have to select the dropdown menu for glsl. Currently it is set to matchbox as default. Then you can see the older glsl copied from an earlier version.
Cheers,
Mark
fred.warren
The funtionality has been integrated into the MUX node. You can now find a "Input Switcher" category at the bottom left of the MUX interface.
fred
Frédéric Warren
User Experience Designer
theonlyandyt
Marvolus, thanks guys.
