Solved by tom_t. Go to Solution.
You could create a link to a directory on a central network location if you have them all talking via NFS or something.
ln -s /usr/discreet/flame_xxxx/matchbox/YourShaderDirectory /mnt/some/network/location/ShaderDirectory
Otherwise you can simply navigate to the centralized location manually when you load shaders.
In either case, keep in mind if the NFS link goes down Flame might get angry. Having not tried I'm not really sure what behavior it might exhibit if you loaded a sequence with missing Matchbox shaders, save the project, and then later fix the problem such that the shaders are found again.. does it remember all the original effect parameters? Not sure (but hopefully yes)
