Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
Looking for the best workflow for "Ken Burns effect" with transition.
2 REPLIES 2
mildseven2013
749 Views, 2 Replies
I'm looking for the best workflow to create "Ken Burns effect" with transition.
I didn a acouple tests.  After inserting images on the yimeline, I put motions with action node in "CFX".  However, when I tried to put transition, there is no handles on both heads and tails.  Is thereany way to add handles?  Or "CFX" is not best choise for images with transition?  If "CFX" is not the best way, what should I choose?
I'm looking for reliable and contstant workflow.
Thanks!
2 REPLIES 2
BKM
in reply to: mildseven2013
Just use Action as the effect on the timeline (2015) I twill give you the full resolution of your clip and since it's a still it will have virtual handles for transitions.  You can enter eh Action Editor for eay animation keyframeing.
Flame/Smoke Editor
Check out the Premiumbeat Smoke Blog
http://www.premiumbeat.com/blog/category/smoke-2/
mildseven2013
in reply to: BKM
Brain,
Thank you for your replay.  Yes you are right.  I can use vertual handles with Action on timeline.
Also I found I can adjust handles inside "Timing."
