I can't remember if I've posted this before. But just noticed that the same thing happens in 2015 SP2 perpetual.
If you have a file structure on a server such as; /sh001/dpx/man_gets_confused.00000000.dpx and you drag the top folder (sh001) into a smoke library, you get /sh001/dpx/man_gets_confused.001.00000000
Good!
Now if you navigate to /sh002/dpx/man_gets_really_annoyed.00000000.dpx and drag the top folder (sh002) into any Library or folder in smoke, you get an empty /sh002 folder and your clip called man_gets_really_annoyed.000000000.dpx ends up inside /sh001/dpx/
This is not cool. Also not cool if you hit Ctrl+z as it removes man_gets_confused too!
Is this mean't to happen? How do you make it stop without having to navigate carefully through every subfolder and drag each clip induvidually.
Cheers,
Angus
I have seen this before and I was aware that it was reported.
My only suggestion instead of going through each and every folder is to go to the root folder with all your sub-folders with media and press SCAN SUB-DIRECTORIES.This should surface all the clips from the folders and than you can drag them into the Media Panel.
I don't believe it will create the folder structure but it will help save on importing time.
Hope this helps.
Regards
Grant
I appreciate your suggestion - but in the case of, say, an EXR render from 3D where the clip description is in the folder structure and the file sequences are just named beauty.exr or ao.exr - it doesn't work to ignore the folder structure.
Is there a plan to fix this? I believe it's a problem that should be solved, not worked around.
Angus
Another note regarding this.
When you do drag a folder with a name that already exists in your library don't hit Ctrl+z (undo) because that will cause the folder with the same name and all it's original contents to be deleted too.
The best way is to make sure none of the source material has common folder names within the hierarchy.
Cheers,
Angus
Which of course is impossible (without making life unbearably hard) in at least two scenarios;
1- cg renders
2- regraded rushes
