I just moved my license form a computer to another and I'm not able to insert any of the locale characters (Romanian). I added the Romanian keyboard to the system and I used a font which has correct characters (is tested on another machine). I can see all the character in Text Node/Keyboard but i cannot insert them from keyboard nor copy/paste them from another application.
Thank you
Steff
Hi Stef.
You need to select the "Romanian - standard" keyboard in Mac OS's Input preferences. You also need a font that supports Latin - Extended characters. The Arial fonts seem to support those.
I've tested this in Smoke 2013x1 using the "Arial Narrow" TTF font and got this:
regards,
Robert.
That's strange. Have you tried the same font I tried? Arial Narrow?
I've just tried under OS 10.9.1 and it worked in there as well. (see screenshot below).
I don't think the actual computer model or year matters. This sounds like an OS config issue.
Try creating a new Smoke user. Also, open the Terminal, type the following command and post the output:
locale
Robert.
Hi Steff.
You should not need to change your entire system language to Romanian to get it to work. There's something going on on your Mac.
All the tests I've done the other day did not require me to change the system language. It's still English.
Can you please post the output of the following command in the Terminal:
locale
Thanks!
Robert
Thanks. Can you please switch the system language back to English-US and run the "locale" command again?
Robert.
