Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
Help - is there any documentation for Smoke?
2 REPLIES 2
adamt
543 Views, 2 Replies
Im a totally new Smoke user, and i am having a heap of issues trying to get Smoke to work right, and part of the problem is because i cannot seem to find any relevant documentation.
Is there anything out there that might help provide a few clues about how to set up the application?
Specifically, I want to use Smoke Setup to direct Smoke to use a folder on my Raid as its default Media Storage Folder.  There is also one that was already entered (AutodeskMediaStorage) which appears to be pointing to the system drive on my Mac. I do not want Smoke saving media to this drive but i cannot figure out how to prevent it from doing so.
When i tried to create a project, the only volume that it will show is the one Smoke created on the system drive.
I tried to open the Manual Edit option on Setup, but without some kind of guidance - its all nonsense to me!
please help!
Adam
Flame 2020.3
2 REPLIES 2
BKM
in reply to: adamt
Here is the answer to you media storage question....
http://knowledge.autodesk.com/support/smoke/troubleshooting/caas/sfdcarticles/sfdcarticles/Adding-ed...
Here is the user guide.
http://docs.autodesk.com/smoke2015-user-guide/
Flame/Smoke Editor
Check out the Premiumbeat Smoke Blog
http://www.premiumbeat.com/blog/category/smoke-2/
adamt
in reply to: BKM
Thanks Brian - that helped!
at least with the install problem...now i need to speak to Autodesk about the Licence code that keeps failing to be recognised!
Flame 2020.3
