Anyone knows how is the way to gang the clips from the source and the record area in the source_rec Viewer?
Ganging the source with the sequence keeps both clips ganged in the thumbnail view. It should do the same thing in the source/sequence viewer, but it's currently broken. The bug has been fixed in an upcomming release.
Jasmin
Which version of the software are you referring to for the bug fix release?
We are using 2015 sp3 and gang is not working in source sequence view!!!
does it work with flame assistant?
Vladimir
There was a bug where a ganged clip did not update when in source-sequence view. I know this has been fixed in flame assist 2015 ext2, but not sure about smoke.
Currently, you can only gang clips in freeform/thumbnail view, and then switch to src-seq view. If in src-seq view, the gang option does not appear. If you want this, you will need to request it via support.
cheers
Jason
