Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
Gang Clips In Source-Rec- View
5 REPLIES 5
786 Views, 5 Replies
Anyone knows how is the way to gang the clips from the source and the record area in the source_rec Viewer?
5 REPLIES 5
frenetj
Ganging the source with the sequence keeps both clips ganged in the thumbnail view.  It should do the same thing in the source/sequence viewer, but  it's currently broken.  The bug has been fixed in an upcomming release.
Jasmin
scottivers
in reply to: frenetj
Which version of the software are you referring to for the bug fix release?
in reply to: scottivers
smoke 2015 sp1.
We are using 2015 sp3 and gang is not working in source sequence view!!!
does it work with flame assistant?
Vladimir
jaseo
There was a bug where a ganged clip did not update when in source-sequence view. I know this has been fixed in flame assist 2015 ext2, but not sure about smoke.
Currently, you can only gang clips in freeform/thumbnail view, and then switch to src-seq view. If in src-seq view, the gang option does not appear. If you want this, you will need to request it via support.
cheers
Jason
