Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
format module error when rendering targa
5 REPLIES 5
229 Views, 0 Replies
for some reason when I render in (16 or 32 bit) targa from Composite I can´t open it in other softwares.
From after effects I get this message:
File format module parameter error
Does anybody know why this is happening?
cheers,
Nína
5 REPLIES 5
Steve_Curley
Duplicate posts are not permitted here, as per the forum rules. The duplicate (in the Scripting forum) has been removed.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Sorry, did not know...
any help would be very appreciated
Steve_Curley
That's why a copy of the forum rules is Stickied (at the top) in every forum.
Can't really help except to say I see the same issue. 8 bit tga works, 16/32 bit doesn't. Don't have many image apps to test in (certainly not PS) - old version of PSP (fails), a resonably recent Gimp (fails) and ImageMagik (fails).
Tested in Composite 32 and 64 bit (2012 and 2013).
Max 2016 (SP1/EXT1)
rudolf_germann
Targa just can store 8bit per channel. It's part of the specs. If you need higher bit depths per channel use EXR or DPX fileformat. Composite should give you a error message if you use bit depths not supported with the fileformat but it does not, never did.
Just make sure that your Rendersettings match the specs for the fileformat you're using because composite does it not for you.
I hope this helps,
rudolf
That would explain it then 😉
Thanks for the tip.
Max 2016 (SP1/EXT1)
