this bug is derth of field in Action
in Batch mode,drag an antion node and add two input
link in two picture and give them two big diffcent Z positon
enable "depth of field"in the nodeSetup of this Action
click priview botton and you can see depth blur enable
but when you render this action or add new CC node on this action output,"depth of field"were lose!!!
why?
Solved by Robert.Adam. Go to Solution.
You can only render D.o.F.accumulation with the legacy camera - and I guess it's not working for you.
The revised camera called Camera3D can output values that can be piped into a Depth of Field after the action output in batch.
Try using a Camera 3D and not the default camera that appears within action.
Add a D.o.F. node and play with the depth-o-gram.
Yep you're right - the depth of field function for the legacy camera in action in batch in flame premium 2014.0.2 is dead.
Previews just fine but won't process in the greater scheme of the pipeline.
Doesn't matter if you enable it under the render functions for the output.
It's a support issue.
Report the bug.
As for the Camera3D node - well that seems to be working with the D.o.F. node just fine.
Take another look at it.
I just thought - you need to enable a z-depth output pass from the action and pipe that into the D.o.F. node for it work as you expect.
Don't forget.
Hi. Consider it reported 🙂
I'll reproduce the issue here and log a bug in our database.
Thank you both so much for the details and screenshots.
Best regards,
Robert.
Thankyou Sir.
I can send you setups if you would like, although the reproduction will probably be faster.
That would really help.
I appreciate it.
Robert.
done & done
Thankyou for your help Robert.
I appreciate your help very much.
FYI flame premium 2014.0.2 RHEL 5 version z820 k6000 (DKU8.5.0)
Than YOU, Philip!
I really appreciate taking the time to create the Batch setup.
I've logged a bug and added both your names to the list of affected users.
Best regards,
Robert.
My pleasure.
BTW, the bug id is SMOK-22810.
If anyone else is affected by this, please let me know and I'll add your names to it.
Best regards,
Robert.
It may have been mentioned already, but the fog tool also has a similar problem, which caused a bit of a headache yesterday.
Anthony Jarvis
Hi - yeah, same here - can't use the Action-based DoF, which is (was) pretty much my favourite thing in Flame! it previews OK but won't render within Batch.
would be awesome if this could get fixed soon as i use it all the time (and it is miiiiiiles better than the Batch DoF node, especially for fine detail stuff...)
