Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
flame premium 2014 sp2 big bug!!!!!!!!!!!!!!!!!!
17 REPLIES 17
Message 1 of 18
auxcc
1286 Views, 17 Replies
this bug is derth of field in Action
in Batch mode,drag an antion node and add two input
link in two picture and give them two big diffcent Z positon
enable "depth of field"in the nodeSetup of this Action
click priview botton and you can see depth blur enable
but when you render this action or add new CC node on this action output,"depth of field"were lose!!!
why?
17 REPLIES 17
Message 2 of 18
in reply to: auxcc
You can only render D.o.F.accumulation with the legacy camera - and I guess it's not working for you.
The revised camera called Camera3D can output values that can be piped into a Depth of Field after the action output in batch.
Try using a Camera 3D and not the default camera that appears within action.
Add a D.o.F. node and play with the depth-o-gram.
Message 3 of 18
auxcc
in reply to: auxcc
Thank you,I'll try it,but preview is good.
why?
Message 4 of 18
auxcc
hi brother,
I have try it and it not work also,
add a new camera3D node in action and change default camera to camera1 in the action node setup,
I get same problem.
that's works in your workstation,I remember in flame2013 it works nice,
Message 5 of 18
in reply to: auxcc
Yep you're right - the depth of field function for the legacy camera in action in batch in flame premium 2014.0.2 is dead.
Previews just fine but won't process in the greater scheme of the pipeline.
Doesn't matter if you enable it under the render functions for the output.
It's a support issue.
Report the bug.
As for the Camera3D node - well that seems to be working with the D.o.F. node just fine.
Take another look at it.
 I just thought - you need to enable a z-depth output pass from the action and pipe that into the D.o.F. node for it work as you expect.
Don't forget.
Message 6 of 18
auxcc
in reply to: auxcc
so it's really a bug, not my problem!
thank you guy!
Message 7 of 18
in reply to: auxcc
so report it...
Message 8 of 18
auxcc
in reply to: auxcc
How?
Message 9 of 18
Robert.Adam
in reply to: auxcc
Hi. Consider it reported 🙂
I'll reproduce the issue here and log a bug in our database.
Thank you both so much for the details and screenshots.
Best regards,
Robert.
Robert Adam
Program Manager
Message 10 of 18
in reply to: Robert.Adam
Thankyou Sir.
I can send you setups if you would like, although the reproduction will probably be faster.
Message 11 of 18
Robert.Adam
That would really help.
I appreciate it.
Robert.
Robert Adam
Program Manager
Message 12 of 18
done & done
Thankyou for your help Robert.
I appreciate your help very much.
FYI flame premium 2014.0.2 RHEL 5 version z820 k6000 (DKU8.5.0)
Message 13 of 18
Robert.Adam
Than YOU, Philip!
I really appreciate taking the time to create the Batch setup.
I've logged a bug and added both your names to the list of affected users.
Best regards,
Robert.
Robert Adam
Program Manager
Message 14 of 18
auxcc
in reply to: auxcc
Thank you Sir.
Message 15 of 18
Robert.Adam
in reply to: auxcc
My pleasure.
BTW, the bug id is SMOK-22810.
If anyone else is affected by this, please let me know and I'll add your names to it.
Best regards,
Robert.
Robert Adam
Program Manager
Message 16 of 18
It may have been mentioned already, but the fog tool also has a similar problem, which caused a bit of a headache yesterday.
Anthony Jarvis
Message 17 of 18
auxcc
really?
I will test it soon, thank you.
Message 18 of 18
Hi - yeah, same here - can't use the Action-based DoF, which is (was) pretty much my favourite thing in Flame! it previews OK but won't render within Batch.
would be awesome if this could get fixed soon as i use it all the time (and it is miiiiiiles better than the Batch DoF node, especially for fine detail stuff...)
