I am getting very jittery playback on our Flame Assist station. Same footage plays smoothly on Flame. Source is prores 422 but is cached on direct attached storage on Mac.
2015 Ext2 sp1
osx 10.8.5
2x2.26 ghx quad core
24gb ram
NVIDIA quadro 4000
kona 3g ouput card
Any ideas welcome. Thanks.
Michael
what res is your footage and bit depth, and what were your cache and render settings set to when the project was created?
If it was left at its default of uncompressed then regardless of the source being prores 422 it will be cached to uncompressed dpx which unless you have a fast raid will not play back on a single internal drive
Hi Joe,
Thanks for your reply. I have tried both prores and uncompressed as cache setting. I have a 5TB direct attached raid. Test Disks reports Read 38fps 0.03 spf 301MBps. This was previously fast enough for 1920 10 bit setup I thought.
Michael
Apparently this is a known bug relating to dual computer monitors and broadcast monitor from an Aja card output.
