Solved by ManChicken. Go to Solution.
How about just adding a GMASK square shaped to fit on a clip of BLACK on your top layer? SHould render faster than Action.
Turn on COMP.
This might be worth testing:
Add a Resize effect to a Gap on a new track above everything, switch the Source crop mode to Free and dial in the height you want... or you can even type in the aspect ratio you're going for and it'll figure it out for you.
Thanks for the alternative solutions, trying them out now.
Better yet, wouldn't it be cool if there was a little button on the overlays menu that simply burned them into your renders on output if selected. Something about the one click solution in menus folks are already using for this purpose just seems a little more intuitive and sensible to me.
Wasn't there a feature like this in Smoke OSX 2012?
