Hi all,
Does anyone know if its possible to grade from a TC edl and then conform the 30 sec and 45 seconder from the graded footage without rendering first.
Any pointers would be helpful.
Thanks.
Jay.
Assuming I understand what you're trying to accomplish, what I do is grade the 45, then load the EDL for the 30 as a new cut (edit>browse), and apply the grade file from the 45 to it (setup>grade). You'll need to render each cut, but this allows you to make as many changes as you need, and save rendering until the very end when you create your deliverables.
Here is a link that might help:
