Solved by yann.laforest. Go to Solution.
Hi Mike,
This is indeed an issue and it should be corrected in a forthcoming release.
Take note that the disk test results show in the latest smoke shell log file available located under /usr/discreet/log.
Please let us me know if you have any other questions,
Yann
that is annoying. However, I find that if I do a 2nd test immediately after it stays there. YMMV
Check out the numbers! Might not be 100% accurate
