Hi
We have 3 flame Suite 2 Flare seat and a 3d department ( 3Dsmax).
we also use Nuke.
And i very confuse about some strange thing on Flame (since 2008 )
Depth of fields : this node don't work at all , i still get a better result in Nuke or even in after effect using "frischluft"
the edge look very wiered .
Uv Map :
If you try to Un-distort in Nuke or in after effect (with-re-map ) , using a UvMap u will get something useable .
if you try to do the same in Flame 2012 , you will get something very wiered.
