Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
Deleting Setups
2 REPLIES 2
mncrnich
377 Views, 2 Replies
Deleting Setups
What is the prefered method for deleting Setup(s) on SMAC 2015 SP1?
I know I can browse to the direction location within the HDD and delete it via the Finder.  However, does that cause any problems because the Setups are entered into an unknown Autodesk Database somewhere?
Sorry for a rather simple question, just being cautious before deleting any Setups on an active job.
TIA.
SMac 2016
2 x 2.4 GHz 6-core Intel Xeon
96 GB 1333 MHz DDR3 RAM
K5000
AJA Kona 3G
ioFX 1.6 TB
Promise VTrak 72TB
Eizo ColorEdge CG276W (artist monitor)
Sony XBR 4K UHD Display (client monitor)
Tags (2)
2 REPLIES 2
BKM
in reply to: mncrnich
Setups that you manually save like CC or Action or even CFX can be deleted via Finder.  You can also delete them via the save/load option as well for the node.
CFX setups also have a folder where the node setups are saved.
CFX setups on clips are saved in the usr/discreet/clip folder and shouldn't be touched... unless you have seen my blog post/video on it. 🙂
Flame/Smoke Editor
Check out the Premiumbeat Smoke Blog
http://www.premiumbeat.com/blog/category/smoke-2/
mncrnich
in reply to: BKM
Perfect! That answers my question.
SMac 2016
K5000
AJA Kona 3G
ioFX 1.6 TB
Promise VTrak 72TB
