How can I crop a frame? I'm using action to place a flat graphic over a white background. The original graphic is on a white background, but after import in the correct aspect ratio, there is black on the sides. I want to place the graphic over white and crop out the black on the sides.
In the Action 'Media' menu there is Crop with Top/Bottom/Left/Right values for each media entry.
Otherwise, use an Action GMask and draw really straight 🙂
Hey Bob,
Turns out that if you go into the matte, there is a "resize" function that can be used as a crop.
