Hi Jaime,
The answer is yes but this is not a trivial process. I suggest you to contact our Technical Support department for assistance in this case.
On the other hand, the behavior you experienced should be fixed in 2015 Extension 3 as the application does not attempt to read the corrupted files anymore. When hitting a corrupted file, the application rejects it and loads the related healthy files only.
In your case, the project would load in X3 without the corrupted setup.
Please let me know if you have any other questions,
Yann
