Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
Conform sees ProRes4444 alpha channel as a match with AAF
3 REPLIES 3
ranchos
529 Views, 3 Replies
Conforming with ProRes4444.   Editor gave me an AAF from Avid.   Unfortunately Flame sees the ProRes alpha channel as a possible match ....so I would have had to manually link all 80 events.   I had him make an EDL which ignored alpha.
FYI
3 REPLIES 3
jaseo
in reply to: ranchos
When in conform, when you Set Search Location, you will see the mediahub general settings at the bottom. Under Clip Settings, you can select either Include Alpha, Create Matte Container, or Ignore Alpha. If you choose Ignore Alpha, the alpha should be ignored...
cheers
Jason
ABC_CNG
I also ran into this exact issue in version 2013.  If you were conforming through the gateway, it would arbitrarily link to the alpha, even if you had selected ignore alpha.  The solution was to soft import all your media to a clip library, and then conform to the clip library instead of the gateway.  Problem solved.
I haven't tried ProRres4444 on 2015 yet but I know that much has been improved in conform since 2013.
Steve Beecher
Flame Artist
Disney ABC Television
Grant.Kay
in reply to: ABC_CNG
Hi Steve,
This should have been resolved in the latest version of Flame (2105 ext 2)… You should be able to set the linking behaviour as Jason described without having to do the 2013 workaround.
Give it a try and let us know 🙂
Regards
Grant
Grant Kay
Principal Learning Content Developer
The Official Autodesk Flame Learning Channel
http://www.youtube.com/flamehowtos
The Official Autodesk Smoke Learning Channel
http://www.youtube.com/smokehowtos
Also available as podcasts on iTunes
Follow me on twitter @discreetuk for the latest training updates.
